- Aug 27, 2012
- 29
Greetings all,
I have been getting error messages on my Pentair sr400NA heater control panel about an AGS problem, so I got a replacement part. Check out attached photo for a bunch o' stuff. So my two questions are (would have been helpful if they had provided instructions!):
(1) When ordering the part, a couple pictures showed white PTFE tape on the threads and another picture showed instead a red stripe on the threads they describe as Loctite (again, see photo). The part they sent me was the red stripe version. Do I need to add PTFE tape to the threads or is that red stripe a sufficient substitute for PTFE tape?
(2) My current AGS sensor has two prongs attached to two identical-looking wires and there is nothing to indicate that there is some kind of right-vs-wrong (top/bottom, left/right) polarity issue. And yet, the meager description on the site where I ordered this part mentions "color-coded wires" (again, see photo) as though there is some correct prong/wire attachment policy I am supposed to adhere to. Is it in fact the case that either wire can be attached to either prong without running the risk of blowing something up?
Thx!
Otherchuck
Thx!
Otherchuck
