Swampwoman said:Hi there. I am also a first year, new-to-pool-school person who was flying blind. Because I hadn't started posting on TFP until AFTER I started the process, I went heavy on the bleach to maintain a state of shock and for a few days used color as my guide until the test kit came in and things really became more clear (in every sense, to me, to the pool water, etc.
I don't think I saw you mention it in your post, but you're backwashing frequently, right? Every time the filter is about 25% above it's normal operating psi (mine is normally in 15-20 range, it's a sand filter, hayworth, and likely same as yours as my pool is similar in size.) Mine was a swamp from a foreclosure, so at first I seriously had to backwash every half hour, but things got better rather quickly. During work day I came home at lunch to shock and to backwash in the beginning.
Just so you know, while I am now going to continue a little longer to clean up some organic staining, it took me about 12 days, constant filtering, and 58 gallons of bleach to date -- way more on the front end...much easier to maintain now. I am attaching pics to show you the color change (no pics from the weekend however until after the vacuuming to waste work on Monday).
Hope that helps. Perhaps you have your kit by now and are ready to hit hard, or perhaps you're already there. Do let us know, because this helps the next googler (And I resembled that remark)
So in terms of bleach cost, I think you're going to be fine with less than $100 worth since your pool is about the same size as mine and your filter sounds like mine (Hayward 220T sand). Be sure to clean out those baskets to keep it filtering well and backwash and keep the water level up and otherwise let TIME + BLEACH + TESTING do the work! Best wishes!
[attachment=0:3ndj26nj]12DaysofShockandAwe.jpg[/attachment:3ndj26nj]
iam4iam said:So how much time does it generally take for added CYA to show up?
Do not adjust ph during shocking. At FC levels above 10 ppm the ph test is not accurate. Do not worry about TA until you are finished with the shocking process. A TA of 80-90 is probably right where you want to be anyways.iam4iam said:Just measured TA. It's 80-90 (80=pink; 90=red)
According to pool calc., it looks like washing soda might be my best bet since I'm on the low end of pH and TA.
So 16-32 oz of washing soda will counteract the pH reduction of the dichlor, but should there be any time lapse between the two additions?
I think you may have a fading endpoint, from the extended test kit directions:iam4iam said:Still very concerned about apparent "off the chart" CH! Is the blue really blue? (I still had light purple after 100 drops!) If it's truly supposed to be blue, I'll have to drain and replace some or the water will never be as clear as I want it to be!
The sample may turn purple during the test, or go to blue for a moment and then turn back to red/pink. This is called a "fading endpoint" and is caused by interference from metal ions. If this happens, do the test again, but this time add five drops of R-0012 before adding any R-0010 or R-0011L. Remember to count the initial five drops in the total.
Yes it assumes the 99%. My opinion is to not mess with dichlor for now. Use liquid chlorine/bleach to dose to stay above your minimum FC level. Put some granular cya into a sock and put in front of the return. Shoot for a cya concentration of 20 to 30 ppm during the shocking process.iam4iam said:I assume dichlor in the pool calculator is referring to full strength? (Walmart carries it in 58%, 63%, and 99%!)
Fair enough, it is not what we typically recomend, but you can do it. For your 21000 gallon pool, you will need ~11 lbs of dichlor. This method can be less efficient since you can't add it all at once, so during the day your chlorine may be used at a higher rate then if you get the cya in there all at once.iam4iam said:Too late. But no worries. Sure, adding CYA would be "purer," but from what I've seen on this site, the only possibly undesirable side effects of dichlor are higher CYA (which I need anyway--assuming "not seeing the black dot" really means not seeing it)
Again, do not adjust ph when over 10 ppm FC! This is important!iam4iam said:and lower pH, which I counteracted with washing soda as per pool calculator.
You haven't answered my questions that I asked about what color the solution is before adding the R-0012? See my previous post.iam4iam said:At this point my chief concern is still my CH!
No problem, link was in that post, but here it is again: extended test kit directionsiam4iam said:Sorry, I missed the post asking about the pre-0012 color and providing extended instructions. I'll investigate! (By the way, where can I find the extended instructions?)
With fading endpoints it can be hard to judge. Take a look at the sections in the extended instructions for both TA and CH.iam4iam said:I assumed the drop that "counts" is the one where the color remained the "destination" color without fading back .
