I took water sample to pool store , after test had a high copper 2.0ppm reading, found stains on parts of liner looking like stained drywall after water ran down it long and rough pattern, dark and lighter in and out, nothing like pictures on the web, The iron test reading was 0, the PH was low 6.8 ppm, TA was low got everything up to par, PH 7.4 , TA 60-80 ppm, salt 3600. Now looking at internet for removal of copper stains it tells me to drop all these setting, and try dry acid to remove these stains, but I thought the acid that was from improper PH TA and CYA causing the copper to come the pool heater heat exchanger, Right now I have a Culater and metal free sequester in the pool. The reason I'm asking whats next is because all I see on the internet is from 2013 or earlier and min. on copper stains most all about iron stains. Please advice me the best to way remove from vinyl liner, Stains 8-10 about 6 ins. wide by 1 to 3 ft. long, any spot treatments as to whole 18 by 36' ? need all help I can get. Thanks,
