Hi everyone, we are doing remodel and our pool leak contractor is probably also doing our pool tiles. We just found a leak at the spa and are about to fix. This sort of spurred together a remodel project.
Previous owner had plaster repairs done in pool and they took terrible. They are splotches of gray in a blue diamond brite pool. The leak and tile guy says he can mix diamond brite and apply it over to blend it. He says he can do this underwater. I insisted I could drain pool, but he says its not necessary. My question is can this even look good if done under water like this?
Also, this guy is insisting that they now make coping to go over current coping. He doesnt do it, but he said the paver people do it and re can repave everything this way and then he will come and remove tiles and re-do them last. Is this possible and should he do tiles last?
When is the time to do a small rock waterfall etc? Before the leak is sealed up at the pool?
