- Aug 29, 2012
- 55
- Plaster
- CircuPool RJ-45 Plus
So I've read comments about testing before adding any salt when converting to salt water pool, but usually it says something like 'you might already have 500ppm.' I measured and I have 1200ppm via Taylor K-1766.
In ground freeform pool (kidney) with spa est 22k gallons
This pool was completely drained and re-plastered in 2021, and I drain down below the returns for winter, and let rain re-fill through the mesh safety cover. I use 10% liquid chlorine and muriatic acid, and for the most part that's all that goes in (I do the other tests but haven't had much need to adjust anything else in a while).
I know I should trust my measurement but is this normal?
