Is it possible? my pool pump seized up during the winter and I had to replace it...bought one on line and I some how ended up with a one speed 1.5 HP Waterway pump. while installing it I noticed that the power cord would not reach the timer. I decided to take the cord off the old one and replace the new one's...when I removed the back cover to the pump I noticed that the new pump appears to have the same electrical connections and the old two speed pump...the only difference seemed to be the wiring connections and the two way switch. The electrical posts were even numbered the same,
What do you all think? is this doable?
Thanks in advance for your help...Bo
Three way switch on old pump:
Two way switch on new pump:
Connections on back of old pump:
Connections on back of new pump:
