How did you add the liquid stabilizer to the pool?
Next time use Pool math to determine who much you need and to see what the effects of adding a chemical (like CYA in this cse). The bottom part of pool math will tell you the effects of adding chemicals, putting in your pool volume this is what I found:
128 ounces of liquid stabilizer will increase your CYA by 21.
4 lbs of granular stabilizer will increase your CYA by 13.
21+13=34. Any backwashing will remove water and some CYA. Your refill water doesn't have CYA, so adding water after a refill will make your CYA come down.
Is this all of the CYA you have added?
