linen said:DE for pools, not DE for gardening.
When you use DE in a sand filter, use the type labeled for pool use. With that said, if you are going to use it, do not use DE at least until after you have replaced your sand. When you have a FC loss of less than 1 ppm overnight, then you will need to replace your sand.chances said:Yes I know....what should I use?
linen said:When you use DE in a sand filter, use the type labeled for pool use. With that said, if you are going to use it, do not use DE at least until after you have replaced your sand. When you have a FC loss of less than 1 ppm overnight, then you will need to replace your sand.chances said:Yes I know....what should I use?
What step are you on in the conversion process?
Have you purchased the K-2006 or tf-100?
Ignore the strips. It sounds like you are getting there, the next step is the <1 ppm loss of FC overnight. This will be difficult to do without the fas-dpd chlorine test.chances said:I hope I'm in the last phases of adding bleach/chlorine. My test kit is a taylor 1004 but so far all the numbers match the aqua check test strips. I can finally see the bottom of the pool.
linen said:Ignore the strips. It sounds like you are getting there, the next step is the <1 ppm loss of FC overnight. This will be difficult to do without the fas-dpd chlorine test.chances said:I hope I'm in the last phases of adding bleach/chlorine. My test kit is a taylor 1004 but so far all the numbers match the aqua check test strips. I can finally see the bottom of the pool.
I am not familiar with the baq sand cleaner. I would recommend following the tfp process and just replace the sand when your FC loss overnight is <1 ppm.chances said:Is there any difference between baquacil sand filter cleaner and any other sand filter cleaner. I still have a new bottle (the kind you backwash through the sand) but sure don't want to add more baqu goo after all this work.
linen said:I am not familiar with the baq sand cleaner. I would recommend following the tfp process and just replace the sand when your FC loss overnight is <1 ppm.chances said:Is there any difference between baquacil sand filter cleaner and any other sand filter cleaner. I still have a new bottle (the kind you backwash through the sand) but sure don't want to add more baqu goo after all this work.
Does anyone else know anything about the baquacil sand cleaner?
chances said:Day 11...just about there....
The pool store guy says I should add any DE to a sand filter...What do you guys say?
linen said:Have you gotten to step 7...fc loss of less than 1 ppm overnight?
Nope keep doing what you are doing. Do you have the fas-dpd chlorine test yet? You really need that one to know if you pass step 7 and can change out your media. Forget about DE for now...that is only good after the conversion is done, and then only if your water is taking a long time to clear.chances said:linen said:Have you gotten to step 7...fc loss of less than 1 ppm overnight?
I'm still losing more than that but guess I'll keep doing what I'm doing unless you have any other suggestions.
linen said:Nope keep doing what you are doing. Do you have the fas-dpd chlorine test yet? You really need that one to know if you pass step 7 and can change out your media. Forget about DE for now...that is only good after the conversion is done, and then only if your water is taking a long time to clear.chances said:linen said:Have you gotten to step 7...fc loss of less than 1 ppm overnight?
I am not familiar with this test kit and I can't find it on Lamotte's page. Do you have a link. All of the colorq test kits I am aware of have the dpd chlorine test which is only good up to 10 ppm and do not have a fas-dpd (different from dpd) chlorine test. Your results indicate it is the dpd test.chances said:fas-dpd Lamotte Color Q digital test kit.
In the recommended test kits, the only test that requires color matching is the ph test. All of the rest are a transition from something to something...pink to clear, red to blue, etc.chances said:Very expensive but I have a hard time matching up colors so thought this was best for me.
Use Borax to raise the ph to 7.2-7.4 before raising the FC for the overnight OCLT test.chances said:After last nights readings I added several pounds of soda ash to raise the Ph but it didn't seem to help.
linen said:I wish you would have asked on here before getting the colorq.
The cya test on the colorq is not accurate enough and the CH test is problematic over 400 ppm.
I would not trust the OCLT with FC at that low of a level. Get it up to 10 ppm (since you can't read higher) tonight and see if you loose less than 1 ppm overnight so you know if you are at step 7 or not.
Yes, look for "20 mule team".chances said:Where can I get borax? Walmart maybe?
During the conversion you want your FC to be at 15 ppm, the colorq only goes up to 10 ppm, so it i not the appropriate tool for the job. In addition it has other problems, some of which I mentioned above. Online reviews are often off base unless you know something about the reviewer or the reviewer is tied to a reputable site (such as ours). We are here to help with the testing, and before you know it, it will be very simple (it really is simple to start with). If it was me, I would return the colorq (I wonder if they will take it back after the reagents are opened).chances said:I know you recommend the Taylor 2006 but I read several reviews where people said it was too complicated. If I am unhappy though with the lamotte I can send it back. http://www.radishandlettuce.com/Lamotte ... t-P47.aspx
TC=FC-CCchances said:Also was I figurine right in my earlier post about subtracting the FC from the TC to see where I'm at?
