My (ancient) solar pool controller has a 24V output to open/close a Jandy valve to direct the water to the solar panels when the sensors for pool/air show heat is available. 3-wire output - common, and a line to open and close the valve. I put my VOM on the terminals and confirmed it is sending 24-30 VAC to one or the other line as the valve opens and closes. My goal is to tap the RS-485 leads from the Whisperflo onto the valve terminals to direct it to go to higher speed when solar panels is open and lower speed when panel is closed. Has anyone tried such a thing before?? The Whisperflo manual implies this is doable, just wanted to know if anyone has ever tried it before. My only glitch is that during the 3 seconds when the valve is in motion it I read current in both lines, then when the valve comes to rest position the 'unused' line powers down to 0 V and the 'used' line maintains the current. Not sure how the Whisperflo would interpret getting signals on 2 channels.
