Moved from here.
There are no trippers on the timer, so the Jandy has continuous power. It shuts down based on no flow sensor. Thinking I should add some trippers to give it power from 9-9, as the pump runs from 8-10.
So what did u end up doing? Just bought house with this set up. VS pump is wired through old school timer with continuous power, so pump start times/rpm/duration is controlled by pump.So, after I had the original Hayward single speed pump burn up I decided that upgrading to a VS pump made sense to help cut down on the energy expense with the pool. I went with the Pentair Superflo VS line for my 14000 gallon pool. It has worked great since last year, although I did find that the pump did not like to play nice with my Eaton BR GFCI 240V breaker. So, made a small change and installed a Siemens subpanel to put in the Siemens 240V GFCI which is rated to play nice with this pump. That seems to have been the right combo. (There is a surge breaker in the panel as well to protect the expensive pump.
Moving forward, looking at getting a SWG in with the pool to help cut down on routine maintenance of the daily chlorinating. Reading on here I am convinced SWG is the way to go. So, did some research on the types out there and decided to go with the Jandy Truclear. My pool is a 14000 gallon type and this SWG is rated for 35000 gallon.
My only question here is hooking up the Jandy to play nicely with the Pentair. The Jandy instructions say to connect it with the pump on the timer. My pump has a built in timer so there is no mechanical timer in use anymore (removed and gone). Just wondering if anyone here has something similar and would say how they hook up and run their SWG with their VS pump. I plan to have the Jandy wired to it's own breaker to keep it seperate from the VS pump line to ensure surge protection for it as well.
