I'm looking to have some plumbing work done to remove the DEL AOP system, Tab Feeder, and Pool Tiger our PB installed. I'm considering adding an SWG at the same time, since it will be more efficient to have it all done at once. But, I'm a little hesitant for the following reasons. I'm wondering if anyone has any thoughts on this that might help me decide whether to go for it with the SWG or just keep doing what I'm doing with LC, which is working well.
FYI the SWG that would be installed would be the Hayward Aquarite AQR940 (which uses the TCELL940) - based on all the research I've done this seems like really my best option unless I want to change automation platforms.
Reasons I'm hesitant to add the SWG:
- CH levels -- from what I'm reading here, I would want my CH levels to be under 450 with an SWG. I have struggled to keep mine under 600 (currently 625). I plan to do another water replacement once the water temperature goes down enough for me to do this in place, but even if I replace half my water it'll bring me down just under 400, and with fill water at 150 it builds over time. I've been doing OK keeping CSI in check even with high CH levels. Does this work the same with an SWG or is the CH going to be an issue even if I keep CSI in check?
- Winterization -- we leave our pool open all year. We do get some freezing temps but last year did ok by heating the water, covering the equipment, and keeping water flowing when it got cold. Does the SWG add any additional risk in the winter, or is it just about the same risk as all the other equipment?
- Changing more than one variable at once seems riskier. Things are going well with my current system using LC. Deleting the AOP and just continuing with LC seems less disruptive and fewer unknowns. That said, everyone here always raves about SWGs so it seems like the way to go eventually and, if so, it would be more efficient to do it now.
