Yep, to operate a swimming pool successfully, you need a functioning pressure gauge (as shown above). Cheap as chips and a cinch to put in. As mentioned above. Get that done and pick up some swimming pool DE at the same time so you can up the efficiency of the filter.
Once the SLAM starts, all previous FC, OCLT and CC tests are no longer relevant. Keep on as you've been doing, including brushing at least daily, and preferably twice daily. Seek out anywhere algae may be hiding or any runoff or source of contamination coming in.
Use FC testing to keep FC maintained at 16 ppm. Keep letting us know the readings. The SLAM continues until the water is clear. Occasionally test and report CC. Do an OCLT any time through the SLAM that you like. OCLTs from before the SLAM no longer matter.
And yep, liquid chlorine does not cloud a pool.
Just wanted to follow up on those things and encourage you as best I can. Re-read the SLAM article, and if anything is unclear, let us know and we can clarify.
