- Jul 13, 2012
- 50
The heater (which does not work) has a green ground wire connected to it...
that wire was connected to my old pool pump before i removed it however from there it goes nowhere or looks like it could have been cutoff if it was headed underground.
And this is the pool cage with a ground wire headed underground, this is where the light is at.
If I connect that ground wire the connects the pump/heater to the pool cage, does that bond the pool? and how do I bond the water?
I have seen youtube videos on how to test bonding by looking for continuity, but how do you test if the water is bonded? do you stick a wire into the water?
