- Mar 30, 2017
- 43
- Plaster
- Pentair Intellichlor IC-40
Hi all, hoping someone has an idea what causes this, ways to alleviate/repair etc. I have two spillway bowls; one looks fine as was replaced a few years ago. This other bowl was from 2016 when pool was built. The outer protective layer has fallen away and the concrete deteriorating. Someone said the inside of the bowl needed to be sealed or painted, as water is seeping through and causing the issue (doesn't seem to be the case). I figured with everyone here someone has ran into this. I couldn't find much help in google, but could be searching wrong terms. We are in AZ to give an idea about weather.
