- Jul 10, 2022
- 52
- Fiberglass
- Pentair Intellichlor IC-15
I'm a first time pool owner and am wondering if I need to be concerned about cracking the heat exchanger in my Pentair Mastertemp 400. I have a leisure pools ultimate 35 with a built in spa. I am able to heat the spa separately, or pool, or both. My concerns center around the temperature difference in the water when I heat the spa and not the pool. When I am done with the spa (usually around 102 degrees), will I do damage to the heat exchanger if I reconfigure the valves back to filter both pools?...this allows very cold water back through the filter and heater.
Another question I have relates to the LCD screen on the Mastertemp 400. It got down to 9 degrees last night and now the screen shows all black cursors and does not read digits. The heater will work, but I have no idea what temp is set. I know LCDs can stop working when they get cold, so thinking it should start working when it gets warmer, but totally ticked that a heater screen isn't working when I need to use the heater most. Ideas?
