I pulled a gas heater and replaced it with a Heatwave SQ150VS this week. The heat pump works just fine when everything is manually controlled, but I'm struggling to get it integrated with an Easytouch Upgrade (PCB dated May 30, 2012) via RS-485. The data lines are connected and the heat pump is set up to use them. The screen shows "under remote control" so I assume comms aren't trivially broken.
On the Easytouch, I installed a dummy 10k resistor on the "solar" sensor input (as per the heat pump instructions). The automation controller thinks that the solar temperature is 77 F. There is no solar heating system or valve. Both pool and spa are set to "heat pump preferred" heat source.
When the temperature is set high enough to want to kick on the heater, instead of the pump speeding up and the heater kicking on, the Easytouch clicks on the "solar" heat source and nothing else happens. Under the diagnostics menu, the heat pump says that it's in normal operation.
Have I done something wrong or is this a firmware bug? The Easytouch is running firmware 2.100, and after reading through this thread I'm not terribly excited to reflash it, though I'm not entirely opposed to it either. Except for the USBDM device, I already have all of the necessary hardware from other projects.
Any advice on steps that I may have missed to get this integration working?
