Hey everyone, I have a Compool 3600 system controlling a pool and spa, that I want to upgrade to be able to control it from my phone when I'm away. I've been doing research, and it seems that, if I want to stay within Pentair, I can either upgrade to the Easytouch system with the Screenlogic2, or get the new IntelliCenter. I plan on doing all of the work myself.
Apparently the easytouch system is recently discontinued? Does that make it worth the increased cost for the intellicenter, or does the easytouch still perform as it should? I ask that because sometimes old "smart" devices become slow and worse to use than the older simpler systems. And how complicated is it to replace the whole panel, if I went with the intellicenter? Also, where would I buy the new systems, so far the only site I found is polytecpools.com.
Another consideration is that in addition to the valves to switch between the pool and spa, I have another electric valve for controlling a water-powered cleaning robot. I see that the compool has an "AUX VALVE" jumper to make an aux switch control a valve. In the easytouch upgrade manual it says that while the compool can have up to 4 valves, the easytouch can only have 2. Is that in addition to the two for the pool/spa? Because I have a manual valve that controls a heater bypass, that if possible I would like to automate as well, so it closes the bypass when the heater is on, and vice versa.
And one more question: I have a Jandy aquapure 1400 salt cell, with its own control panel. Is it possible for either the easytouch or the intellicenter to control the cell directly, so it can also be controlled via my phone? I just replaced the cell recently, so I don't want to replace it, just upgrade if possible.
I also do plan on calling pentair and asking them as well, but I figured it's good to ask around.
