Hello all,
Been a long time reader and finally created an account today because I can't get a handle on what this stuff is.
I had an algae problem a little over a month ago. After a week of SLAMming, brushing, backwashing, the water cleared up pretty quickly. CC was 0.2, OCLT was 0.4. Then a week later, I started seeing some yellowish/brownish stuff begin accumulating on the bottom. When I brushed, the stuff turned dusty and made the pool slightly cloudy. I added enough liquid chlorine and brought FC up to shock level and kept it there for a few days along with brushing and backwashing. I woke up each morning and there it was again. It wasn't limited to the shaded areas and seemed to accumulate anywhere, so I didn't think it was mustard algae, but on the off chance it was, I went ahead and raised FC to Yel/MstrdShock level per the Chlorine/CYA Chart. After maintaining that shock level for 3 days, and again brushing and backwashing, the pool was finally clear. At the end of that SLAM my test results were:
FC: 18
CC 0.0
PH: 7.2
CYA: 30
TA: 120
CH: 200
OCLT: 0.4
Waited about a week for the FC to get back down to target level. The water was as clear as the day we filled it up 3 years ago. The family has been enjoying it for about 2 weeks. Then, I woke up yesterday morning to go test and the yellowish/brown stuff was back. Just one or two spots. Today, there was a lot more.
I've read through the forums and tried to educate myself as best as I can, but I can't figure out what's going on. I test every day. Target levels have been maintained. Pump has been running 24/7 since this all started. I'm not losing more than 0.8 ppm of FC during the OCLT. I've read that yellow/mustard algae is pretty rare, and is often mistaken for pollen. I didn't think it was pollen, because I haven't seen any floating on the surface.
These are results from today. (Taylor K-2006 test kit) CYA is a little higher because I added some stabilizer after the last SLAM when I thought the problem was resolved.
FC: 5.8
CC 0.2
PH: 7.4
CYA: 50
TA: 140
CH: 180
OCLT: 0.6 (Did a test last night)
Any help is appreciated!
FC: 18
CC 0.0
PH: 7.2
CYA: 30
TA: 120
CH: 200
OCLT: 0.4
FC: 5.8
CC 0.2
PH: 7.4
CYA: 50
TA: 140
CH: 180
