- May 23, 2015
- 24,586
- Plaster
- Pentair Intellichlor IC-60
Is there no oversight for public pools? It seems as if that pool should have been closed due to be unsafe if for not other reason than a person could not been seen under the water! Scary! Thank goodness they have you!
Kim
These are community pools within a homeowners association. Therefore it is up to the HOA to govern their use. Records should be kept in case a local health dept asks to see pH/FC logs, but closure is entirely governed by the HOA board, or, if applicable, the HOAs management company.
But yes, I agree, that water was naaaaasssty and a serious swim hazard by not being able to see the bottom.
Sent from my iPhone using Tapatalk,16k gal SWG pool (All Pentair), QuadDE100 Filter, Taylor K-2006
