Hi there -- new to the forum but have learned a tremendous amount already (thank you!). I need some help with my CC levels in my hot tub.
360gal Hot Tub 100 degrees using Chlorine (Sodium dichloro-s-triazinetrione hydrated to be specific).
I've read the "How do I use chlorine" post and learned a lot, but I feel like I'm still missing something.
pH: 7.4
TA: 50
FC: Was 1ppm, added Dichlor to raise to 5ppm
My trouble is with CC. I have been adding (what I thought was) the recommended amount of non-chlorinating shock once a week or so after using a few times per week. I know that MPS can register as CC, but how long does that continue to show up? When I do the test with my Taylor K-2006 (using 10ml of water), I'm adding something like 40 drops of R-0871 to get the pink color to go away after adding the 5 drops of R-003. The hot tub does have a slight chlorine smell when I remove the cover, but it's not overwhelming and I don't feel itchy or stinging when it's in use.
I'm either so far out of the ballpark and my CC levels are truly 20ppm or the MPS is throwing me for a loop. I suspect the latter, but wouldn't be surprised by the former. Is the R-0867 that helps with the MPS showing in CC levels worth it or am I just going crazy?
pH: 7.4
TA: 50
