Good Morning,
I live outside of Chicago. 2 weeks ago my pool became very cloudy after several big storms. My assumption is that some algae formed at the time because the chlorine wasn't quite high enough for all the rain. I had some sediment on bottom of pool. I checked levels at that time (after 2 days of pouring rain) and here is what I had:
FC 2.5 CC .5 Alk 120 CYA 20 or less I added stabilizer and bleach etc. Next reading was FC 7.5 CC 1 ALk 120 CYA 25 again adjusted to shock didn't add more stablizer as it had not been 48 hrs yet. Next reading FC 11.5 cc .5 CYA 40 ALK 130 I got it up to 12 and it held and didn't drop for more than 24 hours. Water has still been cloudy and my readings this morning were FC 8.5 ALK 120 CYA 30
Any suggestions as I had done the SLAM process and everything held for more than a couple of days. SHould I have just kept adding bleach to shock level until it cleared even though it was holding at right level? I was gone over the weekend at a lacrosse tournament so added extra bleach before we left. It poured Friday and Sat/Sun very hot and humid. I will be gone again this weekend but temps will be in mid 70's not sure about rain yet.
Any suggestions would be greatly appreciated. I started using TF kits 4 summers ago and you guys have helped tremendously. I just can't get it to clear for some reason this time. It usually only takes a couple days and I am back in business.
Pool is 28,000 gallons should have mentioned and sand filter.
Tracey G.
Tracey G.
