Closed pool but after plugging the returns, still had some bubbles coming through. Tightening the plug didnt help. Then, went to pump basket and found it full of water even though pipes were running dry air (main drain was open, could water have come through there?)
Removed plugs from pump, filter and heater and tons of water drained out. Does that mean I didnt blow out the lines properly?
My question is if I did good-enough or if there is a danger that pipes will freeze this winter. If so, what do I have to do to close properly?
