- Feb 14, 2021
- 21
- Vinyl
- Pentair Intellichlor IC-40
Today I should start the pool! I’m 99% sure wiring is right, but with the last couple being posted and wrong thought I would ask the forum to take a look.
Filter pump relay
Double pole 20 GFCI
pig tail neutral to neutral bar
red leg to screw 3
black leg to screw 1
SWCG white to screw 2, yellow to screw 4
From pump
pump red leg to screw 3, black leg to screw 1
Control Panel Power
15 amp single pole GFCI
Black to breaker, purple to neutral, pigtail white to neut bar
Pool Lights
From transformer
Black to relay screw 4, white to neutral breaker, white pigtail to neutral bar and black breaker to relay screw 3.
I do have 1 question on the double 20 SWCG/Pump break it has a white pigtail it goes to neutral bar does the line neutral out of breaker also go to neutral bar.
Thanks for looking
Bo
Filter pump relay
Double pole 20 GFCI
red leg to screw 3
From pump
Control Panel Power
Pool Lights
From transformer
Thanks for looking
Bo
