Hi All!
I've emptied a 1969 neglected fiberglass wall and cement pool after confirming all pipes hold air (yay!). I have power washed the walls and floor with just plain water and am about to clean the cement bottom with a muriatic acid followed by a TSP solution cleaning to clear the acid.
I'm wondering if I can clean the fiberglass walls with the muriatic acid or if that should be avoided and if it should be avoided what products should be used to clean the fiberglass walls.
Any advice here will be appreciated!
Thank you!
Mark
Thank you!
Mark
