Adding more photos of what I have hereHello, When I want to clean my pool pump basket, I set the pool pump to "service" mode. However, when I open the cap of the basket, water flows from the basket non-stop. Why is water flowing from it while the pump is in "service" mode? What should I do?
Btw - I also have the pump booster
Thank you! Can you please point the one that I need to close? I assume that the drain should be stain open?You likely want to close that suction valve completely while servicing the pump skimmer basket.
Both of mine always drained both directions away from the pump,When you open the pump basket, all the water in the filter, which is higher, will try to run out of the pump's basket area..
