Hi folks,
I've had a Circupool SI-45 system for about 6 years, and it's always worked very well. In fact, I just replaced the cell a few weeks ago with a SI-40 replacement.
I just returned from vacation to find a pool just starting to turn green, and I find the SWG control unit isn't on. After some voltage checks, I see the internal 15A fuse is blown. I replace it, power the unit on, and the fuse immediately blows again.
So...at this point I'm not sure what to check, or what would cause this other than the control board failing in some way.
Pool: 24kgal, 4300ppm salt, 7.8 pH
The salt level is a little high, I try to keep in under 4000 but accidentally put too much salt in a few weeks ago.
Any ideas what could be going on, or what I should check? I'm comfortable testing other voltages inside the unit if that would help.
