- Apr 10, 2018
- 5,663
- Plaster
- CircuPool RJ-45
Here's an option if you plan to move the SWG...
Cut the cell out of the vertical line. Be careful to allow at least 1.5" (cut in the middle of the 90s and unions) on each side of the unions for couplers.
Cut the long horizontal a few feet back behind the flow switch. Replace the cell with a PVC coupler. That will raise the long horizontal line so you can mount the cell off the ground behind the post. Reconnect the line downward with a couple of 90s.
Another bad sketch, but you'll get the idea.
