Okay so here is my question to the TFP Guru's...
All my water numbers are where they are supposed to be except one: Chlorine i can't get a reading on it at all right now.
PH is on the money, salt is on the money, TA in on, and CYA is at 90. The water is crystal clear!!
i just can't get the thing to hold chlorine...
We just installed an AquaTrol salt generator and it was working just fine and dandy for about 3 or 4 weeks until just recently.
When i originally installed the unit there were a couple of things about the pool that are not the same as they are now:
1. Stairs were not in the Pool at the time, they are now and they are weighted down with 3 concrete blocks.
2. Pool water was only 75-80 degrees, now it is 80-90 degrees.
3. Weather was over cast most days, now bright and sunny most days.
All of the numbers on the unit say it is working fine.
Do you think one of these or a combination of these is eating my chlorine faster than the aquatrol can generate it?
