I experienced a mild case of Mustard Algae around Thanksgiving. I ran the SLAM process which I completed 12/2/16. I've been waiting for my chlorine level to drop on its own; however, I'm not having any quick successes. Here's my test results since the SLAM.
12/1/16 - FC was at 44.5 - It had dropped 1PPM in 10 hours
12/7/16 - FC was at 42
12/12/16 - FC was at 38.5
12/16/16 - FC was at 39 - I added 1lb of Chlorine Neutralizer
12/18/16 - FC was 14 - 1.5" water added to pool
12/19/16 - FC was 19.5 - 1lb of Chlorine Neutralizer added
12/21/16 - FC was 19 - Brought sample to pool store to validate proximity to my readings. They only measure up to 4PPM so they ran what they called an Alkalinity test to verify chlorine level. Said Alkalinity indicated chlorine was within normal range. Not sure what they did; my normal range is 5-7PPM.
My SWG has been off since I began the SLAM process.
My reagents for my chlorine test kit Taylor K2006 are less than 6 months old. I'm using to level dippers of DPD Powder.
I'm using a SpeedStir for chlorine testing at 10ml water mark. The water color before Titrating is a bright red. I'm using the .5 multiplier to compute chlorine level with the drop titration process.
I'm in Central-West part of Florida. Our weather has been warm with cool spells. We've had partial to mostly sunny days. No rain.
I'm positioned to add more Chlorine Neutralizer; however, everything I've read on this site reflects that I should be seeing greater daily drops in FC levels without these additions.
Any thoughts/ideas? This situation really has me stumped.
