I recently switched from liquid chlorine to HTC Cal Hypo shock since I am not around as much this summer to add liquid twice a day. Initially I had good results, with 1lb lasting almost a week. Recently I have been using a pound every other day. Is this normal for a shock to burn off that quick? All of the reading I have done makes it seem like it should last closer to a week. It has been super hot here lately so that might have something to do with it. I haven't noticed any algae and the water is crystal clear, but after 48 hours the chlorine level is under 1ppm. If its burning off that quickly, I might as well switch back to liquid.
Readings about 2 hours after adding 1lb of shock today:
PH 7.8
FC 3.2
Alk 180
CYA 55
PH 7.8
FC 3.2
Alk 180
CYA 55
