I have a Pentair 300 offline chlorine feeder, it's set to zero yet my pool's chlorine level stays above 3ppm. The feeder was installed by the contractor with the feeder "in" line before the filter vs. after (which is what the manual suggests). When I open the chlorine canister while the pump is running, it is full and immediately overflows despite having it's valve at zero.
1. When the valve is at zero, shouldn't that stop any water from entering the chlorine chamber? If so, then the valve is potentially defective. Except it's a new valve and the 3rd after the first two failed within 6 mo's of each other (started leaking/cracked).
2. My concern is that there is too much pressure due to the feeder line attachment before vs. after the filter, though the filter pressure valve shows 20 psi so I don't believe it could dramatically higher before entering the filter. Could the pressure be the issue?
Any other suggestions? My thought is to try to replumb with the filter "in" line after the filter to see if that solves the issue, but I would need to seal the original hole in the pvc pipe somehow- I don't know what to use.
I'd appreciate any help. Thanks, Phil
