Re: confused about HASA web site info
I use Hasa 12.5% chlorinating liquid and it works well. You can use the Trichlor tabs to chlorinate to raise CYA and they will help keep the pH in check since they are acidic. They will also lower your TA which you can let drop to 70 ppm since you'll want it on the low side to reduce the pH rise once you switch back to using only chlorinating liquid. In your situation with a lot of chlorine breakdown from sunlight (you can do an overnight chlorine loss test to confirm you don't have other unusual chlorine demand), I'd have your CYA at least at 50 ppm and then keep the FC proportionally higher per the chlorine/cya chart. Finally, once you've reached your CYA target and switched to using only chlorinating liquid you should set a higher pH target or 7.7 or 7.8 and don't lower the pH to below 7.5 when you add acid. That should help lower the amount of acid you need.
