How do you clean up a mess like this once it happens?That's what we figured. We see it here from time to time. But thank goodness no one was nearby. As you can see, mixing some chemicals is extremely dangerous. But stick around and let us help you understand how to manage your pool. All you need is a proper test kit and some basic knowledge like the link below.
By the way, not sure what type of equipment you have since your signature is not updated. But if you have a sand or DE filter with a mulitport valve, you can run it on recirculate to keep water moving. Stop using any tabs and just use liquid chlorine. Less side effects anyway.
Pool Care Basics Archives
Your one-stop shop for all things TFP to include: ABCs of Water Chemistry, Recommended Chemicals/Levels, Test Kits, Troubleshooting, and much more!www.troublefreepool.com
I just made the same mistake, and don't know what to do to clean it up
