Hi all,
Three separate questions:
1. Salt Levels -- The SWG article says to keep it 2-400ppm above the manuf recommendations. My manuf suggests 3,600. However the pool school article seems to imply that 3,000 is the right level. This seems conflicting. I'm sitting at 3,000 now so need some guidance on what the right target level should be in the Pool Math app for me.
2. CL -- The FC measurements in Pool Math have a target with a number of 6-11 for me currently. (Currently my FC is 8.5). But the dual-chamber plastic gauge that we are to measure on a regular basis has two number columns, one for CL, one for Br. And the numbers are much lower than the targets in pool math. How should I be reading the numbers on the gauge? Am I just more checking that the yellow color is within the min-max range?
3. TA - My TA still sits higher that I read it should be. I've fought to get my PH down to where it is. The pool math app isn't recommendation any more acid for PH, but under TA, it is telling me to add more acid to get my PH down to 7.2 or so. Should I keep adding a cup of acid every 1-2 days until that PH number is closer to 7.2 to see if my TA Improves? (The pool is about 2 months old now)
In case anyone need it, here are my current readings:
FC - 8.5
PH - 7.5
TA - 90
CH - 400
CYA - 80
Salt - 3000
As always, thanks!!
FC - 8.5
PH - 7.5
TA - 90
CH - 400
CYA - 80
Salt - 3000
As always, thanks!!
