I just read recently that after adding CYA you shouldn't backwash for a week. What if your pool is green, gross, and will take days and lots of backwashing to clean, but if you don't add chlorine it's just going to get greener and greener because it's so freaking hot and humid out. And if you are adding chlorine you have to have a good CYA level (or the chlorine is gone within hours) but you don't. So would you still add CYA even though you know you'll have to backwash in the next week and eventually add CYA again once your pool is finally clear?
Pump broke last season so it wasn't closed the way we'd like. Pool is green and has a lot of bugs, leaves, and other grossness in it. CYA is less than 20 (my test only goes down to 20) even though it was 40 last year and only water to the skimmer was removed. Backwashing is a must or else the filter is going to get filled with gunk fast. CYA and Chlorine are also a must because if we don't stay on top of that, the algae will get worse and worse.
18 x 52 above ground pool, sand filter.
thank you
thank you
