Check out these pool store recommendations...
Got the test kit. Here's the results:
pH 7.2
FC 29
CC .5
CYA @ 200 (i diluted with half tap water)
TA 220
CH @ 400
So, plugging these numbers into the calculator, the csi seems ok at .08.
The water is a bit cloudy and dull, but not green.
Its ridiculous that their pool store had the CYA at 80, and the FC was 10, but "too high", so use this chem out o lower it, when a couple of days later the FC is 29.
Continued use of pucks with lower the pH and the TA and raise the CYA, which is already in the stratosphere. No scale remover will not lower the CH. They need to just use bleach.
Thoughts ....
Replace 75% of the water to lower the CYA and then SLAM.
Ideally, they would replace 75% of the water and SLAM.
Realistically, with about a month left in their pool season, they wont do this. Regardless, I'll try my best to educate them on the logic behind this, and show them this site and how to use the pool calculator.
That TA is surprisingly high (testing error???) given the use of pucks, unless a lot of baking soda was added. Neither of them are a big deal at this point as long as the pH is controlled.
The elephant in the room is the CYA.
It probably isn't worth your time and effort to convince them what the proper way to fix their pool is for only a month longer of swimming. Let them deal with it and starting next season retest and start over. Let them research this site during the winter and hopefully they will be enlightened.
If they do let you drain this season, be prepared for at least a 75% drain and refill. This is going to be the only fix now or next season unless ammonia takes over.
Sometimes over the winter some bacteria ends up breaking down the CYA and often resulting in high levels of ammonia which then requires a lot of chlorine to get rid of it.
The minimum listed for a CYA of 100ppm is 7ppm with a target of 12ppm and shock level of 39ppm.
So theoretically, for a CYA of 200ppm, min is 14ppm, target is 24ppm, and shock level is 78ppm.
BTW, remember pH test does not work with FC > 10ppm.
Starting to see why this is a bad idea?
