OK so not really a Stenner but I figured anyone searching for info on using a peristaltic pump would start with Stenner threads.
I recently purchased a 250 gallon spa and wanted to automate sanitation as much as possible. Just like when we had the pool built I strongly considered a SWG but ended up going with a pump instead mostly because I already did the pool and that is what I know. My goal was to reduce the cost by going with much less expensive components than I used on the pool. I figured the spa is a good place to experiment because if I get a failure leading to a green swamp dumping the water and starting over is not a big deal.
First challenge was the pump, at 250 gallon of water I needed a pump that can dose extremely slow, since the most easily sourced timers only go down to whole minutes. 1ppm FC is 9ml of 10% chlorine. Stenner pumps are geared so you get high torque low RPM, this makes small amounts over longer time periods easily achieved. The cheap eBay pumps I was looking at are not geared making them high rpm low torque. For the most part you can't slow them down if you want them to work reliably. I bought a 12V pump like THIS if you search eBay or amazon for "Dosing Pump Peristaltic Dosing Head for Aquarium" you will see dozens of examples from about $6 to $15 depending on where it's coming from. These pumps claim the flow rate is 0-100 ml/min but there is no info on how to achieve the different rates and after playing with one I don't think it's possible, or if it is, not easily and consistently. The pump I bought using a 12V 1amp supply like THIS runs at 60ml/min with a 3mm ID roller tube.
Now how to get that down to 1, or 2PPM per min so I can use a WiFi programmable smart plug like THIS. If you do a search for "Infinite Cycle Loop Delay Timer" you will find THIS, again like the pumps the prices vary depending on where you buy it from and how long you are willing to wait. I was able to run it with the same $6 LED power supply. By shorting the on/off molex, moving a couple of shunts, and adjusting a couple pots I was able to get it to activate only once each time it's powered and could choose any thing from 1 to 100 seconds. The WiFi plug is set to turn on for 1 min once a day, I have the relay set to activate for the first 20sec of that, giving me 20ml or aprox 2ppm any time the plug is activated.
Put it all in a water proof project box and I was good to go. For now I just have the pump tube draped over the side of the spa into the water until some time passes and I gain some confidence in the longevity of the pump and roller tube. At a replacement cost of around $7 for the pump and less than $1 for the roller tube if I can get 4 months or more without having to replace something I will install a T into one of the return jets inside the spa cabinet. My total cost was $42 could have been more like $35 if i had been willing to wait longer for parts, in fact I have ordered 1 spare of each component except the WiFi plug just in case.
This build could also serve well for those who manually dose but want a somewhat inexpensive project/solution for vacation dosing. As an added bonus if you have an Amazon echo you can dose during your soak with your voice. Another option is the on/off molex could be wired with a switch so you can dose at the push of a button. If I ever do that I will probably do it with a second relay connect to an always on 12V supply that way I can adjust the relay for for 0.5 or 1ppm per button push.
for this initial setup I plan to not do any maintenance and run the system until I get a failure, I will report back to this thread when I do for any one that is interested.
