I have an inclosed deck. Had to climb through access door in the deck to access pump, sand filter. I am getting too old to be climbing through hatch doors and working in confined spaces. So I bought an in ground pump and put that and the sand filter outside the deck, above the water line, now the water pumping into the pool through the return line is working but weirdly. It runs and pumps the water just fine for maybe 7 to 10 minutes, then the water surges hard then goes back to normal, i this cycle is continuous. Any thoughts, I have drain lines that I opened up to flush any air that might be causing this. Thanks for any help
