Hi all,
Problem trying to figure out.
Opened pool and noticed a good bit of championing in the site glass for my pump. Also can bleed air from filter every 10 minutes. I do not see any leaks.
I replaced lid, seal, and o ring with new and it did not resolve the issue. After about two weeks pump motor went bad and pump was old so I replaced the entire pump. After replacing pump still have problem. Everything looks good but still championing a lot and filter gets air I can bleed off.
Any suggestions or help would be appreciated. Also will this hurt anything if left running this way? Thanks
