My pool's un-adjusted CH is 90. I am aware recommended ranges are 250-650 (TFP a,b,c's), 350 to 550 recommended | 250 to 650 acceptable (TFP Pool Math), 200-400 recommended | 150-1000 acceptable (APSP and NSPF). I go by the TFP recommendations for all the other chemical levels, however I'm trying to understand what benefit raising the CH will have to my gelcoat fiberglass pool, PVC pipes, sand filter, SWG, or the other chemical levels? I've done the reading on CH, and I don't get it, at least in the case of a fiberglass pool. Bringing the CH to the TFP number requires adding 10+ lbs of Calcium Chloride. That's a lot of snow-melter in the pool, and I'm hesitant.
CH = 90
TA = 90
CYA = 55
ph = 7.6
FC = 3.5
CC = 0.5
CH = 90
TA = 90
CYA = 55
ph = 7.6
FC = 3.5
CC = 0.5
