Hi all, I’m looking for some advice. I’ve got an old Sylvan pool. The cement block around one of the skimmers is raising on one side and lowering on the other. I’ve been in the house about five years and I would say it’s moved about a cm in that time. I’ve attached some pictures, you can see where I put some concrete and caulking to fill the gap on top between the pool coping and the cement block where the skimmer is.
You can also see inside the skimmer where there is a big crack/hole on the right side.
Questions:
1) should I do anything about this? Try to dig out the back side underneath and backfill with concrete?
2) should I fill the plastic hole inside the skimmer? With caulk? With epoxy?
I would really appreciate some advice. I just got the pool plastered so am not going to do anything major.
Questions:
