I hope someone experienced can assist me. My Taylor 2006 kit says once the FC measurement is completed then add 5 drops of R003. If the solution turnis pink then add R871 counting the drops until the solution becomes clear. Does the 5 drops of R003 apply equally if the FC is say 16 as it would if the test solution was say FC of 5. I'm concerned that the FC 16 test solution has more liquid in it than the FC 5 test solution has. Therefore the the larger test solution of FC 16 would dilute the 5 drops of R003 applied during the test. Would it effect the accuracy of the CC test?......Many thanks John
