I have an 11 year old pool with a cascading waterfall that has been working just fine until last summer. I've spent the last few months trying to fix the issue with no luck. I've backwashed and cleaned out everything I can to ensure proper water flow. The right side of the cascading waterfall shoots out water with lots of force while the left side of the cascading waterfall flows less than it use to. I've cleaned out the front flow area with a hacksaw blade and a waterfall cleaner tool I found online. Nothing seems to help. If I turn off the waterfall for a couple weeks, the force of the water on the right side is not as strong (still stronger than it was in the past), but after a few days, the right side of the waterfall is once again forcefully blowing water very hard out of the opening.
I've considered cutting the water line to the waterfall and inserting a snake like camera I have to see if I see anything odd but, honestly, I'm not sure what I'd be looking for other than debris.
Any ideas from this esteemed group? Thank you for any thoughts. - Mike
