- Jul 13, 2013
- 1
Re: Caretaker 99 in floor pool cleaning system giving me iss
I have had the same issue before. Check the small filter that is inline on top of the caretaker it is called the dome strainer, if it clogs up that will drop your pressure significantly. I order a second one so I can just have a clean one to trade out every 3-4 weeks. You usually have to have a big pipe wrench or channel locks to get that pipe loose where it attaches to the caretaker head. Careful when you tighten it back up to not cross-thread because it will leak and you will probably have to replace that piece to get it to stop. Here is a picture of what it looks like http://www.infloorpoolparts.com/caretak ... aine5.html Good Luck,
