- Jun 14, 2019
- 39
- Vinyl
- Pentair Intellichlor IC-40
Started slam seven days ago after water seemed slightly cloudy. No visible algae on floor or walls and no green water. Lowered ph to 7.2, CYA at 60 (several tests so confident) raised FC to 24 slam level. Cc was present. Pool very clear within a couple days. Other notes…
Brushing 1-2x daily and running robot, no visible algae on floor but slight ‘dust’ when brushing
Checking FC 4-5x daily
Backwashed sand filter several times though no Psi increase.
Added DE to skimmer
Had storm 3 days ago which brought some debris in pool…cleared the next morning
Pulled ladder, nothing inside
Cleaned back of both skimmer doors, foam and door had some black but not slimy
Cottonwood still blowing in pool…no run off from landscape that I see as the ground slopes heavily away
Washing vials after testing and regents new
Letting drops fall off end and using speedstir
Current loss of 2 FC overnight, started with FC loss of 4
SWG off and pump 24/7 at 1700
We are leaving for vacation tomorrow for a week. I hate to see all my hard work wasted. Should I turn back on the ic40 SWG if I don’t pass the OCLT tonight? It was keeping up prior to slamming set at 40% for 24hr. Our pool is on south side, full sun from 8am- 7pm. Any other suggestions? I haven’t pulled the drains so thinking I may have hubs do tonight. Anything else? I wasn’t sure if my led lights are removable?
Added DE to skimmer
