- Jul 8, 2020
- 9
- Plaster
- Hayward Aqua Rite (T-15)
Long time listener, first time poster. This site is amazing by the way, kudos to all of you and thanks for the wealth of information to a newbie pool owner. We installed a new gunite pool last year (water filled beginning of August) and, since then, I've been diligently testing with a TF-100 test kit, ignoring pool store advice (although they "need to test" for my plaster warranty) and educating them that they don't understand what's in the "other 80%" of the stuff they sell. It's been a fun year.
Ok, more importantly, we have a 23,500 gallon pool with an auto safety cover. In the fall, I found that my FC would easily creep up if the pool stayed closed for even a day or two. So I routinely would find FC creeping above 5.0ppm and would lower the SWG % down from my 50% setpoint, to 10-20%. I noticed CC could also get to 0.5ppm but a nice day of sun with the cover open would clear that up easily.
This spring has been quite a different story. I feel like I can't keep FC in my pool, and have had to subsidize the Cl levels with gallons of bleach (I've probably used 5 gallons over the last 3 weeks). I did an overnight FC loss test about a week ago, and I lost 0.5ppm.
One strong theory I have is that there is a lot of pollen, seed pods, etc falling in the pool. I have skimmer socks on and replace them every couple of days. However, when the cover is open it's also usually sunny. Also want to make sure it's not something else or you all might have some other recommendation.
Current SWG setting is 75%, with the pump running 12 hours per day (7a-7p). Water test with TF-100 is below.
pH 7.6
FC 3.5
CC 0.0
TA 100
CH 275
CYA 65
Salt 3300
Borates 30
Temp 79F
CSI -0.21
I just added some CYA, after this test, to pull that up a bit into the "ideal range". This morning I tested the FC at 4.0 when I opened the cover, so lost about 0.5 during the day today -- again, can't tell if this is sun or the junk falling into the pool. I'm just surprised I can't maintain the levels even with the SWG running so much higher than I've ever had it. Yesterday I added a gallon bleach to bring the FC up to 5.0 (before people went in the pool).... again SWG running @ 75% and I was at 4.0 this morning.
Btw, I did just do a SWG inspection as the OmniLogic timer went off. It was clean and looked brand new. Any other thoughts? Am I just being paranoid and should run my pump longer/at a higher setting/add bleach and this is mostly normal?
pH 7.6
FC 3.5
CC 0.0
TA 100
CH 275
CYA 65
Salt 3300
Borates 30
Temp 79F
CSI -0.21
