swbill, did you have the cell off when you did the FC test? Doing the FC test at shock level is difficult due to the accuracy required by the test. Also, by my calculation you lost 13ppm FC the day before from noon to 7pm which shows you have organics. You should run the test with the SWG off and the FC level around 3 - 8 ppm from sunset to sunrise.
When did you run the SWG test, before or after you shocked? What you are looking for is the difference between the pool FC level and the output of the SWG. So if the pool FC is 5ppm and the output of the SWG is 7 then you know you are getting 2ppm out of the SWG. Is this what you did?
