My pentair microbrites are all starting to die one by one. When I replace them all can I change them to the Jandy Hydrocool? They both screw into the 1.5 inch return fitting and they even list an option for RGBW pentair color series but wasn't sure if i was missing something? I have the intellicenter and use the app to make color changes, turn on/off, etc. Thanks in advance!
The Jandy WaterColors Nicheless LED lights with HydroCool™ technology use an innovative, energy-efficient design that harnesses the cooling power of water to create a cooler running, longer lasting* light. Designed to fit in a standard 1-1/2" return fitting, these lights are smaller to accommodate complex pool designs, and operate at lower wattages, while providing the same brilliant illumination as previous models.
*Based on internal testing
Read more
Inground Pool Light: Jandy HydroCool Light | Jandy
4 1/2" Long or 5 1/2" Long Dimensions
6W12W24WWattage
50 ft.100 ft.150 ft.Cord Length
RGBW Pentair Color Series
RGBW, P - SERIES 12W 100' CORD
ENGINEERED WITH NEW HYDROCOOL™ TECHNOLOGY TO PROVIDE LONG-LASTING PERFORMANCE.
SKU #JLU4C12W100PThe Jandy WaterColors Nicheless LED lights with HydroCool™ technology use an innovative, energy-efficient design that harnesses the cooling power of water to create a cooler running, longer lasting* light. Designed to fit in a standard 1-1/2" return fitting, these lights are smaller to accommodate complex pool designs, and operate at lower wattages, while providing the same brilliant illumination as previous models.
Read more
6W12W24WWattage
