- Aug 31, 2021
- 216
- Plaster
- Pureline Crystal Pure 60,000
I just received a Calimar VS pump that I'll be installing over the weekend. Also purchased a pump automation control board that I will use with an iAqualink system and relays to control pump speeds.
My current fixed-speed pump is controlled by my main filter pump relay. I noticed that my NG heater is also connected to the load side of this relay (ie when the filter pump is switched off, the heater control panel is completely dead). I assume this was done as an additional safety step to ensure that the heater isn't manually switched on via the control panel while the filter pump is off.
It it safe and/or typical to have a heater be powered up 100% of the time? I guess I'd be counting on the flow/pressure sensors to ensure that it wouldn't be fired without the pump running (and/or with the pump running on low speed).
Which of the following wiring options would be preferred?
Option 1: wire both VS pump and heater to 240V line side, so both are powered up 100% of the time. Heater on/off controlled via iAqualink fireman's switch.
Option 2: Switch heater from 240V to 120V, use one of the iAqualink relays to BOTH close the "speed 2" circuit on the VS pump (high enough speed for heater and spa to run) AND power up the heater. ie on the relay:
LINE 1 = 5V input from automation adapter
LOAD 1 = "speed 2" circuit for VS pump automation adapter
LINE 2 = 120V hot
LOAD 2 = 120V hot to heater
(for Option 2, heater would still be controlled via iAqualink fireman's switch, but the heater control panel would be switched off unless the appropriate VS pump speed was selected).
Sorry for the long-winded question and thanks in advance for any feedback!
LINE 2 = 120V hot
