Re: Can I run Cartridge Filter with the 4 cartridges removed
Carlscan26:
"Try rotating the return valve to spa only as I suggested" Which valve are you referring to? The two actuator controlled valves rotate together if
done with the electric controller. I can manually rotate either one individually. As mentioned, the valve "under the towel", rotated alone manually,
emptied the spa. I can rotate the other spa valve ..the "spurting" valve, alone or with the "under the towel" valve.
THANK YOU!
Carlscan26:
THANK YOU!
